Is it possible to turn M/F values into Boolean number format?
I have a large dataset where one column has M or F (male or female) string values.
I think that I can set Number format for this column as BOOLEAN. This way I could operate in the column as if were numbers.
I see the post https://ask.libreoffice.org/t/change-boolean-to-yes-no-instead-of-true-false/19118, where my question is answered, perhaps, but I cannot figure out how to do it. Please, a word of advise.
I do not want to rewrite the column with search/replace (I know it’s feasible, but I’m exploring this possibility of working with the data as is…)
The problem is: Formatting does NOT change data. So setting a number format for Text will be ignored (or to be more precise the fourth segment of the formatting will be used for text in a cell for numbers: @
So while it is easy to show something different for numbers, it is impossible to do the reverse for the cell. However: You may use the solution with =IF wich erAck gave in your linked thread in other cells:
You are totally right!
What a misconception I had!
Yes, I’ll change according to erAck. Thank you!
