Are there plans for an official port and support on OpenBSD sparc64?
I’m still using OpenOffice 3.3 on OpenBSD 4.9 sparc64 and I will appreciate to migrate to the new generation product.
Hi @kalta59, Did you ever find a build of LO that would work on your hardware? Did you ever try to build LO from source?
Thanks MagicFab, but this version is only for OpenBSD i386 platform. I’m searching for OpenBSD Sparc64.
Hi @kalta59,
It appears that the answer appears to be ‘No’ – there is no current OpenBSD Sparc64 port of LibreOffice.
Would you like to help us make such a build available? If you can get the suite building on that platform and help us out with a builtbot, then my guess is that the devs would be happy to have your help!
