One of my documents has lot of small text boxes and images which I regularly need to delete and replace with different content. Obviously one can select and delete these individually but is there a way to select and delete them all in one go? I’m using LO version 5.0.5.2 on Ubuntu 15.10
It is possible to select multiple blocks of text or other items and then action them together. First select the first item, then hold down the CTRL key and select the next items until you have selected them all. Then select delete in your case.
Extracted from the LibO Writer manual: Chapter 3 Working with text.
Hope this helps. Peter
I tried that but it doesn’t seem to work with text boxes or inserted images. In the page I’m thinking about I have some thirty of each of these
