I’m trying to set the fill color of 1 shape to be the same as another.
I’m left to guessing from several colors that are close to the original shape, which is a waste of time.
For a quick solution, you can use the “clone format” tool you find in the toolbar. For a more “formal” solution, you can define a style with the correct color, line, etc. Then, apply the style to the object.
