Is it possible to use LO Writer to edit this xml DocBook manual: The Debian Reference Manual?
(BTW, it’s currently being publishing to html and pdf with something called ‘publican’, if that helps.)
I can see that LO Writer can output DocBook format, but but another, older Q here suggests this might not work so well.
Also so far, I’m not sure how to input it into Writer.
So any ideas about how’s the best way to edit this manual? I was hoping for a WYSIWYG editor for this task, rather than using a text editor. Also not sure how to set up appropriate styles in Writer, and/or to get all of the tags to work.
