By using macro, is there a way to determine if the LO macro settings are enabled, or at least determine the current folder is a “trusted location”?
I made a Base, connected to a MySQL database, however, if the users can access the tables, they can see what they are not supposed to see. I know I can filter the the tables, but it is impractical in my situation. To solve this, I learned from this forum on how to hide the Base app window. However, they can still access the tables if they open the Base with “Disable Macros”. I know adding “trusted location” is a solution to this. But what if the user manages to copy and paste the .odb file to a different location and still access the tables.
So I was thinking of creating a dummy .odt (as a launcher) file to check if the macro settings is enabled and the trusted source is still there. and runs the odb file from there.
Or is there a better way? Thanks.
