I am having a problem find my database in Libre Base. I’m working on a separate machine with SCADA software, which creates it’s own DB when installed called WinCC. I can browse the machine and find the database, but can’t find the database in Libre with an user created ODBC and I’m hoping someone can give me some things to try. Here is a short summary of my issue:
Problem:
When creating a Libre ODBC Database to the user created data source server DESKTOP-SFD84LN/WinCC, the WinCC database doesn’t appear within Libre Folders: dbo, Information_schema, or sys.
What I’ve Done:
Created windows install media for windows 10
Installed Windows 10 pro OS
Installed Siemens Runtime Pro, V18
Installed .net 3.5
Installed Libre office 7.5.5 Windows x64-x84
Installed Java windows x64
Created user ODBC data source WinCC, to DESKTOP-SFD84LN/WinCC
Created a database with database wizard in Libre Base, selecting Connect to an existing DB type ODBC and selecting the WinCC Database
A short note: I’ve got another machine set up and it is working there, and as far as I know the machines are set up the same. We have no issue opening Libre and finding the WinCC DB.
I’ve reinstalled libre and java, re-created the OBDB link, and I’m running out of things I know to try.
Thanks in advance,
