Issues obtaining info from SystemParametersInfo
Hello everyone,
CPU threads: 16; OS: Windows 11 X86_64 (10.0 build 26100); UI render: Skia/Raster; VCL: win
Locale: en-CA (en_CA); UI: en-US
I’m trying to determine size of screen without the task bar. For some reason the API call is not returning any information back. Although, I’m not getting any error message, could there be anything wrong with the values I’m passing?
Option Explicit
Declare Function SystemParametersInfo Lib “user32” Alias “SystemParametersInfoA” _
(ByVal uAction As Long, ByVal uParam As Long, ByVal lpvParam As Any, ByVal fuWinIni As long) As Long
Type screenRect
x1 As Long
x2 As Long
x3 As Long
x4 As Long
End type
Sub testSPI()
Dim rect As screenRect
Dim result
result = SystemParametersInfo(48, 0, rect, 0)
freelibrary(“user32.dll”)
Any help would be very appreciated.
Thank you for this. However, any idea why wouldn’t the call to DLL work?
nope. maybe because SystemParametersInfoA returns a Boolean, not a Long ?
SystemParametersInfoA function (winuser.h) - Win32 apps | Microsoft Learn
just checkin, does it work for the documented example : Declare Statement ?
Indeed I did make a mistake there, but I just tried with a proper definition and no luck. Nonetheless, thank you for the suggestion.
change to
ByRef lpvParam As Any
then the declare works
Good luck,
ms777
This completely makes sense as the third variable is in/out. Thank you so much!!
