Java installation on a MacBook Pro running 15.3.1
I’m new to LibreOffice, which I just installed. When I open the app, I get the message that I’ve seen discussed here “Please install a JRE and restart LibreOffice.” I have followed the link, but the instructions are way over my head and the discussions here are also beyond me. Could someone point me to a simpler set of instructions, please? I switched to LibreOffice because I need the Master Document feature, just to provide some context.
I should add that this Oracle page has download links for Mac, but I’m still unclear which one and how to install.
How to install Java (JRE/JDK) so that LibreOffice could use it?
Thank you. I had read this page before, but I missed the short paragraph at the end about installing on Mac.
You could try this:
https://adoptium.net/fr/temurin/releases/?version=23&os=mac&arch=aarch64&package=jdk
Thank you, I think I finally figured it out. I appreciate all the helpful responses.
