I have a libreoffice base document which is connected to a mysql database, and I don’t want to have to type in a password when opening the document, so I am using the “JDBC” option for the connection rather than MySQL (JDBC). This allows me to specify a URL for the database with the password embedded.
However, when opening a form with subforms, the subforms fail to get populated, and give the error:
Parameter index out of range (1 > number of parameters, which is 0).
The SQL command leading to this error is:
SELECT * FROM prm_test.addresses WHERE ( personID = :link_from_ID )
This does not happen if I switch the connection type to “MySQL (JDBC)”, but that’s not really an acceptable solution as there’s then no way to store the password.
