Dear community,
Using LT 5.2 after a clean install and a user profile reset leads to a massive constant single core CPU load, even without typing. The problem occurs on blank documents too as soon as I start typing.
If I disable and enable LT again from the extension manager (without restarting) the load is gone until I type again.
Had anyone experienced this problem too?
OS: Ubuntu 20.04 (LO is in pre-release)
