I am trying to export xls into dbf via Libre command line with this line :
scalc —invisible -convert-to dbf MATIKGL.xls
File is converted and it’s functional except Libre changes header (first row), where the column type (C for character, N for numeric) and maximum size of the field is defined. E.g. column size is 19 (max 19 character in cells for that column) but Libre reads the largest input in that column, counts number of characters of that specific input and changes it from 19 to for instance 10.
How to tell Libre from command line to skip changing first row (header)?
One more thing, even if I try to change field size to 19 in DBF manually using Libre scalc and save that file, when opened 19 is once again changed.
