Libre Draw: Drop Shadows Not Saving with Tables
I am using Version 4.0.2.2 (Build ID: 400m0(Build:2))
I have created several .odg files with Libre draw that has several tables with a drop shadows. After save the file and reopening the file, the drop shadows are not saving.
Anyone now if this is a bug? Or a resolution?
Which OS are you using?
I made a test with Version 4.0.5.2 (Build ID: 5464147a081647a250913f19c0715bca595af2f) on XP/SP3 and the shadow remains.
File format: odg
Maybe upgrading is the solution for your problem. However I cannot make a test using your version.
