Libre Draw using Visio templates
As an electrical designer, I have used Visio templates to make quick work of line drawings.
I have become an avid user of Libre Office, but it seems that I still need to use Visio because of the templates it offers.
Is there any template set for Libre (specifically the “Industrial Control Systems” templates)?
Tony
Can’t you open Visio templates in LibreOffice Draw?
I don’t know if there is a template for you but have you had a look at http://templates.libreoffice.org/ ?
Hi @shortcircuit,
I don’t believe that there’s currently any Visio template sets in LibreOffice, but perhaps you could import an existing Visio template set?
After-the-fact I know, but others stumbling over this may like to try the “VRT Network Equipment” gallery from extensions.libreoffice.org, or direct from the maintainer here http://www.vrt.com.au/downloads/vrt-network-equipment
