I will create a  MSWORD document, such as an outline for a  LAW/ Contracts  class.
I want to add/import/copy  a LIBRE flowchart into the MSWORD document so others can read .
What is best way especially if others are not using LIBRE?
from MDK
I guess you msword document it’s opened with LibreOffice, test y copying the flow chart in that document, save and reopening shows fine the flowchart. If not paste it as image and it should work.
