I have an ellipse shape. It is divided into 4 parts by lines and I would like to set the background color of each quadrant independently. Is this possible in Draw or is there some workaround to achieve this? Thanks!!
Windows/Linux Version 4.2
You have to create the ellipse, duplicate it four times (all in the same place), then create a rectangle, which would cover the part which you would like to crop out. Now select one rectangle and one ellipse and choose from menu: Converting (or changing or something) → Shapes → Intersection. Repeat 3 more times.
