Version: 24.2.2.2 (X86_64) / LibreOffice Community
Build ID: d56cc158d8a96260b836f100ef4b4ef25d6f1a01
CPU threads: 2; OS: Linux 6.5; UI render: default; VCL: gtk3
Locale: en-NZ (en_GB.UTF-8); UI: en-US
LibreOffice updated itself a few days (week?) ago, and it now prevents me from opening base files. Correction: I can open the base files fine but whenever I try to open one of the forms contained within I get an error message such as:
SQL Status: S1000
Error code: -25
error in script file line: /my_database_file.odb 43 at /home/buildslave/source/libo-core/connectivity/source/drivers/jdbc/Object.cxx:173
With past LibreOffice updates, one typically has to go to Tools → Options → Advanced and select a Java Runtime Environment. I have two listed:
Private Build 18.0.2-ea
Ubuntu 11.0.22
Selecting either of those two and restarting does not resolve the issue. I get the same error message.
I tried uninstalling LibreOffice 24.2.2.2 and reinstalling LibreOffice 24.2.1 but encountered the same problem, meaning I am unable to access any base files, whereas I was able to open them fine with earlier versions of LibreOffice.
