Hi,
I am on Win 7, i5 laptop.
I used to have OOo on this computer, no problem. I installed LibO successfully (Windows main installer), and if I click the startup icon, it doesn’t start. The mouse cursor is “thinking” for a few seconds, and then nothing. No “soffice” in the running processes either. Try to start it by opening a DRAW document, same happens.
Restart computer, reinstalled, same problem :/.
Try compatibility mode, same problem.
I am quite stuck, I don’t even have an eror message or so I could work with.
If anybody can help he will have my extended thanks
