I try to install Libre Office 6.3 and 6.2 in W10 Pro (1909/ OSBuild 18363.476), and it doesn`t run in normal mode, but yes in security mode.
What can I do?
Regards,
Gabriel.
What can I do?
Regards,
Gabriel.
none of the General Installation Issues could help me…!
If your installation of LibreOffice runs in Safe Mode then most probably your user profile is corrupt and you need to reset your user profile.
To do so perform the following steps:
Advanced
(click on the word Advanced right above Help
button) and click Archive User Profile
buttonReset to factory settiings
[x] Reset entire user profile
Apply Changes and Restart
Hope that helps.
Thank you kindly for your answer, but it still doesnt work. I
m installing the last version of LibreOffice… Do you have any clue what`s going on? Regards.
Hello partners… I fixed my problem.
Starting LibreOffice in “Safe mode”, after trying almost everything, the last thing I did was “Disable hardware acceleration”, and once applying the changes, and restarted, it did it in normal mode, and running everything well.
Now I need to realized what happens with my OpenGL/ OpenCL
My best regards,
Gabriel.
