Hi I am using libreoffice 6.4.1 Base in endeavour OS linux (arch). I am having a problem with date control in a form where I set it to dropdown. When I enter the field it takes a while to respond and when I click the down arrow it again takes a while to responds after the second click. However I can not click in any other form control after I click on the dropdown and cursor is gone. If I close the form and reopen I can then enter other fields.
I have tried on a laptop with EndeavourOS and same thing happens. Tried Openoffice on the laptop and that is fine.
Has anyone got this problem or can you help out. Am I missing a graphic plugin or something. I have to use windows libreoffice which is fine.
thanks
