I’m new to LibreOffice (Version: 6.2.4.2 (x64) Win 10 Pro)
I have a test FileMaker Pro 18 Advanced Database  I want to use as a  data source (populate a spread sheet generate a graph etc) .  Connecting to FileMaker via  JDBC .  That works.
Queries from Database->Tools->SQL…Execute SQL Command works.
Building a Query
All my LibreOffice  Base queries return.
LibreOffice Base
Data Content could not be loaded
[FileMaker][FileMaker JDBC] No results were returned by the query.
SQL Status: 02000
Error code: 27110
I’m guessing “generated” SQL statements don’t match up with what I’m “hand coding”.
I tried editing the content.xml queries. That had no effect. I tried a lot of other things as well. Same error message. Does LO log SQL statements it generates? I’d quit and do it another way with another solution but the “hand typed” queries from Database->Tools->SQL…Execute SQL Command works.
Any thoughts?
I can run queries fine
