Greetings, dear friends
I’m facing an issue with external links in LibreOffice Calc that’s been quite frustrating. I have two .ods files located in the same folder. One file is supposed to load values from the other using formulas like:
=INDIRECT("'./spread1.ods'#$Export.A8")
However, every time I open the spreadsheet that loads values (indexer.ods), I have to manually fix the external links. LibreOffice Calc prompts me to select the file (spread1.ods) again, even though both files are in the same folder.
I suspect it might have something to do with how LibreOffice handles relative paths or updates external links. I’ve tried using absolute paths in the formulas (file:///full/path/to/folder/spread1.ods), and it works, but these spreadsheets are supposed to be in a version control system, editable and working for anyone with access, at any location - so absolute paths would break this integration
Could someone please advise on how to resolve this? I would like a solution that prevents LibreOffice Calc from requiring manual intervention to update these external links every time I open the file, as I’m loading from many external files into 1 single “indexer” file.
Thank you in advance for your help!
