I am using centOS 6.5 and libreoffice packages all installed. When I am trying to convert document using command line getting error.I can’t recognize the problem.
I am using following command
libreoffice --headless -convert-to html resume.docx 2>&1
or
soffice -env:UserInstallation=file:MY_PATH --headless --convert-to pdf:writer_pdf_Export --outdir files 11.ppt 2>&1
or
/usr/lib/libreoffice/program/soffice.bin --headless --convert-to pdf:writer_pdf_Export --outdir files 11.ppt 2>&1
When exceute the above command I am getting following error
/usr/lib/libreoffice/program/soffice.bin X11 error: Can't open display:
Set DISPLAY environment variable, use -display option or check permissions of your X-Server
(See "man X" resp. "man xhost" for details)
