I get the message ““LibreOffice” can’t be opened because Apple cannot check it for malicious software”
Hello
please check one of these:
- https://blog.documentfoundation.org/blog/2019/10/22/libreoffice-and-macos-catalina/
- “LibreOffice.app” can’t be opened because Apple cannot check it for malicious software.
- Safely open apps on your Mac - Apple Support
and many more, if you type Catalina into the search box of this site.
Hope that helps.
If the answer helped you to solve your problem, please click the check mark (
) next to the answer.
