Link to external data does not work
I am trying to link to external data at this link:
https://www.amfiindia.com/spages/NAVAll.txt
The text import tab pops up with all the tables correctly filled out. But if I click OK, the Available Tablle/Ranges does not fill up. This is just plain text data. Why does it not work? Someone please help me out here,
Thanks,
Regards,
Sachin
Link to external data works on HTML tables such as http://coinmarketcap.com/ .
To be able to use other means as in your case or JSON data, you would need to write the code to interface. Even a simple import of the data you presented is only possible for the data in each individual fund (data is separated by ;).
