Hi,
I am trying to do a similar thing to the previous thread (LO Base SQL Insert in Macro)… and am starting with the code that’s already posted there, and made some tweaks…
I get an runtime error message at the line “Stmt.executeUpdate(strSQL)”. I’m on HDSQLDB embedded, MacOS Mojave 10.14.6 and LibreOffice 6.4.5 (mac 64-bit). Will appreciate the help.
Thanks!
-Steph
Error Message:
BASIC runtime error. An exception
occurred Type:
com.sun.star.sdbc.SQLException
Message: Wrong data type:
java.lang.IllegalArgumentException.
The code i am working with:
Sub Insert2TblOrders
Dim context
Dim DB
Dim Conn
Dim Stmt
Dim Result
Dim TodaysDate as String
Dim strSQL As String
Context=CreateUnoService("com.sun.star.sdb.DatabaseContext")
DB=Context.getByName("IKK_V7") '<-
Conn = DB.getConnection("","")
Stmt=Conn.createStatement()
TodaysDate =Format(Now(),"dd/mm/yyyy")
strSQL=
"INSERT INTO "&"""INVOICES"""& _
"( " & """WARGANO""" & _
", INVOICEDAMOUNT"& _
", INVOICEDATE"& _
", INVOICEID"& _
", STATUSID"& _
", ORDER_ID)"& _
"(Select "& _
"WARGANO"& _
", sum(AMOUNT) AS INVOICEDAMOUNT"& _
", "&"'"& TodaysDate &"'" & " AS INVOICEDATE"& _
", concat('INV',""WARGANO"") AS INVOICEID"&_
", '103' AS STATUSID"& _
", ORDER_ID"& _
" From "&"""ORDERS"""&" group by WARGANO,INVOICEID,STATUSID,ORDER_ID);"
Conn.close()
(edit: codified code)
