LO basic - how to comment out blocks of code in the basic editor?
Hi,
Sorry, but I can’t find how to comment out blocks of code in the LO Basic editor.
The microsoft VBA IDE has buttons to (un)comment blocks of code, but I can’t find those in LO. And I also can’t find an equivalent of /* … */.
What are my options in LO?
tnx
Commenting lines manually? Coming with a patch introducing “(Un)Comment block”? (Yes, there’s no multiline comments syntax in BASIC language.)
tnx for replying!
140004 – Allow commenting out or disabling of code blocks in BASIC IDE
The shortcut Ctrl + Alt + C is used to execute it.
It works similarly to other code editors such as Kate and VSCode.
Whe can also use tags to avoid the execution of code parts
Goto Jump
print "Hello"
print "how are you"
Jump:
print "you can't see the previous prints"
