LO not finding its help files
The last several times I have updated LO and have installed the GB language and help modules (from Download LibreOffice | LibreOffice - Free Office Suite - Based on OpenOffice - Compatible with Microsoft), the help files have not been available. Attempting to access local help returns a message such as
Firefox can’t find the file at /tmp/lu52542fadz9.tmp/NewHelp0.html.
The file does exist and attempting to open it directly produces the same message.
Assuming that is where the help files should be (which seems a bit strange) why is the help not opening correctly?
Ubuntu 22-04 LO 24.2.2
Thank you @fpy. I think you are right. I prefer not to use flatpak, but the other options have problems as well.
