I am using mac os x “10.13.6 (17g12034)”. unfortunately when I open the presentation of libreoffice which is an .odp file, my mac shows the “font names” in a wrong way. To give an example: my friend is specifying the font Catamaran, which shows in my windows libreoffice as it should be; but in my mac it is a very different font. How to overcome this problem?
if your presentation is shown in a different font on your macOS, then most likely
- You macOS has not installed that special font (font Catamaran is not a font provided by LibreOffice and hence it may not be available on you macOS if you haven’t installed it on macOS. Fonts are to be provided by the operation system)
=> **Solution 1:** Install the font on macOS (Solution 2 not required in that case)
– and –
The presentation has been saved without option
[x] Embed fonts in the document- seeFile -> Properties -> Tab: Font=> Solution 2: Set the option and save your file once more (Solution 1 not required in that case)
Hope that helps.
If the answer helped to solve your problem, please click the check mark (
) next to the answer.
