I have a macro that processes a row and if the date cell is blank I want to copy the date from the cell above it. The code works fine, but then if I sort that column, the copied cells appear at the bottom of the list, evidently because they are not actually date format. I’ve tried a lot of solutions (chatgpt gave failing examples 9 times!) so how can it be done? here’s a section of what I have now:
oRange = oSheet.getCellRangeByName("A3:Z" & lastRow)
For i = 0 To lastRow - 3
oCell = oRange.getCellByPosition(0, i) 'date column
If oCell.getString() = "" Then
' Replace empty with value from above
oCellAbove = oRange.getCellByPosition(0, i - 1)
oCell.setString(oCellAbove.getString())
If oCell.Type = com.sun.star.table.CellContentType.TEXT Then
'Convert text to date
On Error Resume Next
oCell.String = CDate(Trim(oCell.String)) ' Converts date formats
On Error GoTo 0
End If
End If
Next i
