Making a cell reference with data in other cells
I have two calc sheets in the same spreadsheet and would like to draw data from one to the other. The column and row references change.
Using the ROW command I have put on sheet1 the row number from sheet 2.
So I now have 100 items with the row number attached.
A column reference is also added on sheet1.
I would like to now tell sheet one to collect data from the columns and the rows that have been allocated.
i.e ‘sheet2’.&J2&J3 - J2 containing the column and J3 containing the row number generated by the ROW command. These are on sheet1.
Looking at the forums, I have tried a few things but to no avail. Keep getting a REF! error. Can anyone help please.
Kind Regards
Maybe try INDIRECT(‘sheet2’.&J2&J3)
Hi, Thank you for taking a look. I have seen INDIRECT on my searches. What I have tried either throws up REF! or Error. As written here seems to be Err:509. I can get it working to pull data on the same sheet but not to pull from sheet2.
Sorry, I was on my phone and it isn’t always easy to see what’s there, you need double quotation marks that haven’t been converted to curly quotes, try =INDIRECT("$Sheet2."&J2&J3)
My understanding of INDIRECT from what I have read in the forums and from your suggestions is that you make a formula out of text in " " and cell references.
It did not work on my spreadsheet, so I came and asked. Your suggestion was the same as I had read but still does not work on my spreadsheet.
I have now tried it on a new blank spreadsheet and it worked so it obviously is correct. I will have to have a play. Thank you very much for your time.
Error 508 pair missing, possibly only one quote? See Error Codes in LibreOffice Calc
Have now copy and pasted data to new spreadsheet and it is now working.
