This is better than hand entry for any larger dataset, but I’d say this is a bit of a workaround at least up to Excel 2016, since up to then Excel recognizes the picture and text put on the clipboard by LO, but doesn’t offer a way to Transpose text/cell data during paste. That means a person would have to paste into Excel as is then copy and paste again, using Excel’s Paste special…Transpose [or some in-workbook transpose operation].
Sorry to turn this into an Excel forum, but to get exactly what the OP wants, things really should happen in Excel. Here’s a macro that can be assigned to a key combination in Excel. It will paste either multi-row, single-cell text or multi-row, multi-cell text selected and copied in LO Calc into a multi-column formation in Excel. The pasting will happen starting at the currently selected cell in Excel. This will do exactly as the OQ asked, no need to use the Data functionality in LO first.
Option Explicit
Public Clipboard As New MSForms.DataObject
Sub TransposePasteFromLO()
'Clipboard access from Excel Help HQ
'Tested on Excel 2016
'Add a user form to this project (VBAProject/Workbook)
'so that VBA autoloads MSForms...it may not be available
'as a reference item under Tools-References.
'To do this right-click on Modules, select Insert-UserForm
Dim DataObj As New MSForms.DataObject
Dim Selection As Range
Dim Contents As String
Dim Result As Variant
Dim ResultLength As Integer
Dim Value As Variant
Dim Index As Integer
Set Selection = Application.Selection
DataObj.GetFromClipboard
Contents = DataObj.GetText
'For multi-row text within a cell
Result = Split(Contents, Chr(10))
'For multi-row selection
If Not IsArray(Result) Then
Result = Split(Contents, vbCrLf)
End If
'For a combination of multi-row text and multi-row selection
'result will be multi-row selection as separate cells
'and multi-row text within a single row of a single cell separated by a space
ResultLength = UBound(Result) - LBound(Result) + 1
Index = 0
For Each Value In Result
Selection.Offset(0, Index).Value = Value
Index = Index + 1
If Index = ResultLength - 1 Then Exit For 'Don't write blank cell at end
Next
End Sub 'TransposePasteFromLO
If OP needs assistance on adding this macro or the dummy UserForm, I’d be willing to respond with the caveat that this is not an Excel forum.
