MariaDB & MySQL SQL syntax: using boolean AND or OR in Base queries
In Base query design what’s the SQL syntax for AND and OR when connected to MySQL?
Typical usage examples:
Select True And False As `x` From `Foo`;
Select 1=1 And 2=2 As `x` From `Foo`;
Select if(1=1 And 2=2, 5, 6) As `x` From `Foo`;
Select if((1=1) And (2=2), 5, 6) As `x` From `Foo`;
I’ve tried everything I can think of including ...AND(1=1; 2=2)..., but keep getting a syntax error.
? Also, why is it again that there is this SQL interpretation process that goes on?
BTW, in the Tools | SQL window (uninterpreted) the following work as expected:
SELECT 1=1 And 2=2 As `x` From `Foo`;
SELECT (1=1 And 2=2) As `x` From `Foo`;
SELECT (1=1) And (2=2) As `x` From `Foo`;
SELECT if((1=1) And (2=2),5,6) As `x` From `Foo`;
Also of note is that
SELECT 1=1 As `x` ...
does not work as expected. Instead you must write
SELECT if(1=1,true, false) As `x` ..
Thanks.
Using LO 5.3.3.2
If starting from the design view, click the toolbar icon to Switch Design View On/Off. Then click the toolbar icon to Run SQL command directly to avoid the interpretation process. Now everything works as expected.
query SQL view
Note: I do not know what benefit the interpretation process provides. Invariably, my queries are run directly. This makes it simple because the same behavior occurs from a MySQL prompt as from a Base query.
The interpreter preforms some basic syntax verification before passing on. However, this is for generally for HSQL v1.8. It does provide for a user input parameter such as :enter_something. With Run directly on, this is not available.
Thanks guys! Also just created this enhancement suggestion: https://bugs.documentfoundation.org/show_bug.cgi?id=112801
Here are some workaround’s:
OR:
|| provides OR functionality, i.e. it returns true for
True || True
True || False
False || True, but false for
False || False.
NOT:
If(condition,FALSE,TRUE) – This is messy, but it works, i.e. if condition is true this returns false.
AND:
This boolean identity can then be used to produce AND from OR:
x AND y = NOT (NOT x OR Not y)
Therefore
If( If(x,FALSE,TRUE) || If(y,FALSE,TRUE), FALSE, TRUE)
For example:
If( If( x=1, FALSE, TRUE ) || If( y=1, FALSE, TRUE ), FALSE, TRUE )
And this works in MySQL, but oh, what a mess.
As I recall, in HSQLDB this requires CASEWHEN rather than simply IF. But unfortunately, || does not provide an OR function in HSQLDB.
From the HSQLDB1.8 User Guide:
SQL Expression
[NOT] condition [{ OR | AND }
condition]"
But I can’t seem to get it to work, not even in HSQLDB.
If testing for nulls:
Try concat([list of your values]), and then test for IS NOT EMPTY - often much simpler than using if(isnull(...), ..)
