I cannot get MINVERSE to work with matrices larger than 2x2. The attached spreadsheet illustrates the problem. A 2x2 matrix is inverted perfectly, but 3x3 and 4x4 return only Err:502 in all the inverted matrix cells.
The method I am using to enter the formula is to highlight the block of cells where the inverted matrix is to be placed, then while the block is still highlighted, in the first cell entering e.g. MINVERSE(B12:E15) and pressing Ctrl-Shift-Enter. The formula with curly brackets around is inserted into all the cells, but only the 2x2 inverted matrix displays numbers.
Sorry - I now realise that the examples I was using for the 3x3 and 4x4 matrices can’t be inverted, and that the formulas work correctly if the values are changed.
Matrix Inversion.ods (9.8 KB)
