You helped me with Base but I have more questions. How did you get your screen shots of Base on the Forum page? How can I get more help with my project from you? I don’t understand some of the information you gave me.
WRITER Question: Ultimately I want my database, which holds all my records to communicate with Writer. I want my form letters to pull out certain records (I specify) to print the letter for a specific person, addressed to the specific client and referencing a specific plaintiff’s attorney. Is this possible between Writer and Base?
Don’t want to steal Drew’s thunder… but the short answer to your question is a mail merge into Writer for form letters. It’s a multi-step process where you first register the data source, then insert fields where name, address & other info should appear.
