I’m looking for ideas for ways to create a single Impress document containing several custom slideshows (for various subsets of the slides) that will sequentially show each slide in the selected custom slideshow subset while playing that slide’s audio narration track and automatically move to the next slide (all the way to the end of the custom slideshow).
I’ve come close to achieving that by making use of
Slide Transition/Modify Transition/Sound/Other sound…
to select an mp3 narration audio file for each slide and setting the Duration to a slightly longer play time.
Unfortunately, this approach seems to require that all the audio files remain external to the Impress file which then makes it difficult to simply email the presentation to anyone.
Possible solution # 1: Make audio files already attached/embedded in the slide or elsewhere in Impress file available for selection from:
Possible solution # 2: Provide options for autoplaying an audio file included on a slide AND once the audio file finishes, provide a way to move to the next slide in whichever custom slideshow was selected. The advantage of this solution is that it might be able to be engineered to work for embedded video clips as well.
I apologize if I’ve somehow missed an obvious solution to get narrated slideshows to play through on their own.
It would be acceptable to have to have separate Impress files for each custom slideshow.
