I am running LibreOffice 4.1.4.2. I have a standard document that I copy and past the contents into Lotus Notes to create a note to send. Imbedded in the document is a web link I also want to send. If I try to copy and paste the contents of the document to the note everything comes over except the web link. I have tried both .doc and .odt formats and copy/pasting normal and special. Nothing works. I can open the same documents (the .doc ones) from Word (2003) and do not have any problems.
Is there a security (or other) setting in LibreOffice I need to set so I can copy and past the link successfully. I seem to be able to do it between Writer documents so it may be unique to Notes. But again, I can successfully do the same copy/past from Word.
