Need help with dictation software
hi, i am trying to use windows 11 dictation software with libreoffice to work on a novel. i want to be able to automatically capitalize a word after quotation marks but it doesnt work. is there a solution? thanks
Try:
Microsoft - Dictate your notes in OneNote
Unfortunately too cumbersome for writing a novel
Hrbrgr
December 19
Try:
The punctuation comes from the Windows 11 dictation software, not Writer, although Writer will underline potential grammar errors with a blue underline.
After a very short play with it, I would recommend turning on Automatic punctuation but that still won’t add a capital letter where it wouldn’t normally be, you would need punctuation such as a full stop or a question mark. I think there would be a learning curve but you could quickly improve from initial results
For those with Windows 11 and who want to play with it, the Windows key+H turns it on, the Settngs icon opens a dialogue to turn on automatic punctuation. More info at Use voice typing to talk instead of type on your PC - Microsoft Support
