Yes that was the default in OpenOffice, as the other was an extension then. It seems to be a known topic, discussed here:
An package in AUR may solve your problem:
The answer that AndyRTR gives is lame (in my opinion). Since it’s difficult to maintain the package, he decided to avoid the Report Builder (which I also need harder than trying to learn Python scripting).
That’s the reason I am trying to make the AppImage to work with Python in Manjaro, @Wanderer
@LobaLuna: if your issue is already solved? … ignore the suggested workaround!
The following is testet
sudo apt-get purge libreoffice-script-provider-python
( 1. only for me to test you dont need that)
> sudo cp pythonscript.py ……/libreoffice/program/pythonscript.py
> sudo cp scriptproviderforpython.rdb ……/libreoffice/program/services/scriptproviderforpython.rdb
Hi, @karolus!
It’s not solved yet. I’m going to try your solution. Give me a couple of days. I’ve been very busy at work. Thank you very much in advance!
Hi, @karolus
No, within the new AppImage are those files included, but they do not show the HelloWorldPython. I tested in Manjaro, with AppImage 24.2.5, or a rpm-parallel installation…
Funny thing is in Arch, yes, I see the HelloWorldPython (BUT not the Report Builder for Base).
It appears only Debian-like distros fit the requirements for LibreOffice
