Hi All,
I’m sure it’s a dirty word or grubby topic in some quarters around here, but I’ve been using ChatGPT to help me learn how to work with more advanced formulas, and also handle some particularly difficult areas of a sheet I’m building.
Having got that out there, I’m painfully aware of how wrong the AI can be sometimes, so I love the fact that sometimes a good old human expert master can be just the tonic and a welcome sanity check needed.
Before I go ahead and reformat my entire huge spreadsheet along the lines described below, can anyone with skills better than mine comment on these statements from ChatGPT (o4-mini-high)?
Cheers.
CT
To avoid the performance hit of scanning a million rows (or even running COUNTIF over tens of thousands of cells), you can redefine your named range without any volatile functions and by only ever touching your fixed 21:10485 block. Here’s how:
1. Dynamic Named Range via INDEX–LOOKUP
Instead of OFFSET+COUNTIF, use two INDEX() calls separated by a colon—one to find the first non‑blank (“>0” or “EXCLUDED”) and one to find the last—with MATCH() and a LOOKUP() trick, respectively.
2. Why This Is Fast
Non‑volatile: No
OFFSET(). The only functions areMATCH(),LOOKUP(),INDEX(), and a handful of simple string tests, all of which only recalc when their precedents change. - Limited scan: You only ever scan the fixed block DA21:DA10485 (and Z21:Z10485), not the entire column or worksheet.
Auto‑adjusting: As soon as a formula in DA21:DA10485 changes from
""to">0"(or vice versa), your start and end pointers shift, and the named range resizes itself on the fly.
By keeping your DNR definition focused only on the bounds of your data (i.e. cutting out the leading/trailing blanks), you get a small, tight range. Then you layer whatever content‑based filters you want in the formulas that use that range. That separation of concerns:
- Keeps the named range itself fast and simple (it never changes unless you add truly blank rows at the top or bottom).
- Gives you maximum flexibility—if tomorrow you need to test for “<5” or for dates in a given month, you just swap out the test in your
MATCHorSUMPRODUCTwithout touching the DNR.
Efficiency gains
Non‑volatile recalcs
INDEX, MATCH and LOOKUP only recalc when their direct precedent cells change. You avoid the “every change, everywhere” cost of OFFSET(). -
Bounded scans
You only ever look at CR21:CR10485 (or DA21:DA10485), not the entire column. That can be thousands of rows faster than scanning 1 048 576 rows or an entire sheet. -
Automatic resizing
As soon as your formulas in that block flip between"",">0", or"EXCLUDED", your named range’s start and end pointers shift immediately—no helper cells or manual tweaks required.
