Is there a way, from basic script, to obtain at runtime the name and module of the function running and possibly, after a function call, the name and module of the calling function?
Thanks
No. It is impossible in StarBasic. Not even in debug mode where the list of calls only shows the routine names without library and module.
Good question. I’ll create an enhancement request (to determine the library, module, macro name of the script being executed). Something like GetScriptURI().
Thank you both. With “traditional” tools I was already quite convinced that it was not possible. I was hoping for some lesser known API.
Even in the latest releases of ScriptForge, I haven’t found anything like it.
Better ask about the problem you want to solve, NOT about how you think it can be solved!
You could use another macro language (such as Python) with any IDE you prefer.
Thanks everyone. I don’t know Python, I work in basic scripts. In the management of “on error goto” I always call a parameterized function to display errors and messages, and I wanted to integrate it with the name of the function and of the module that had generated the error.
For this, as a first attempt, I was looking for the solution in basic script.
I write the name of function to the bug calling
Sub myBigFunction
on local error goto bug
rem code
exit sub
bug:
bug(Err, Erl, Error, "myBigFunction") 'name of function written as parameter
Sub bug(sErr$, sErl$, sError$, sFce$)
msgbox("line: " & sErl & chr(13) & sErr & ": " & sError, 16, sFce)
stop 'don't show bug alerts from more functions
Thanks. That is exactly what originated my request. I also have a similar user function (err_handler) called from the label L (… on error goto L …)
Each of my modules contains a module constant (sModName) with the name of the module. Currently I call “err_handler” passing as fixed parameters sModName and the name of the function, and as variable parameters specific messages related to the specific function.
But when you have a library with many modules each with more than 20-30 constantly evolving functions, having two more parameters to add each time makes the code heavier
If your “bug” function from the calling code could have found by itself the path of the function (function-module-library name) it was much more convenient
In addition to the above, sometimes macros are called using the invoke method, in which case you need to know the names of the library, module, macro…
For such cases, I am forced to have a “special” module in the library (below is a fragment):
' lang:en
' Returns the name of this library.
Function ThisLib_Name() As String
ThisLib_Name="MYLIBRARY"
End Function
' lang:en
' Returns the type of this library.
' Types:
' `0` document library.
' `1` user library (My Macros & Dialogs).
' `2` LO application library (LibreOffice Macros & Dialogs).
Function ThisLib_Type() As Long
ThisLib_Type=0
End Function
Unfortunately there isn’t a possibility how to do it in Basic :-(.
I use extension BasicIDETools Basic IDE Tools | Apache OpenOffice Extensions with some my fixes and modifications, and inspired by this extension I add one icon to the Basic Toolbar with macro VlozFci that inserts the code for new function. Maybe you can modified it and create a dilaog window also with listbox of Basic Libraries instead only simple msgbox.
Sub VlozFci 'put the code to the Basic Editor
dim s$, p()
s=inputbox("F name = Function name"& chr(13) &"S name = Sub name", "Function or Sub", "F ")
if s="" then exit sub
p=split(s, " ")
if p(0)="S" then p(0)="Sub" else p(0)="Function"
s=chr(13) & p(0) &" "& p(1) & iif(p(0)="Sub", "", "()") & chr(13) & chr(9) &"on local error goto bug"& chr(13) & chr(9) & chr(13) & chr(9) & "exit "& LCase(p(0)) & chr(13) &"bug:" & chr(13) & chr(9) & "bug(Erl, Erl, Error, """& p(1) &""")" & chr(13) & "End " & p(0) & chr(13)
vlozDoSchranky(s)
dim document as object, dispatcher as object
document=oDocBasicIDE.CurrentController.Frame
dispatcher=createUnoService("com.sun.star.frame.DispatchHelper")
dispatcher.executeDispatch(document, ".uno:Paste", "", 0, array())
rem ----- operations with system clipboard
global gsClipboard as string
Function LclipboardgetTransferData( aFlavor as com.sun.star.datatransfer.DataFlavor)
if (aFlavor.MimeType="text/plain;charset=utf-16") then
LclipboardgetTransferData()=gsClipboard
end if
End Function
Function LclipboardgetTransferDataFlavors()
dim aFlavor as new com.sun.star.datatransfer.DataFlavor
aFlavor.HumanPresentableName="Unicode-Text"
LclipboardgetTransferDataFlavors()=array(aFlavor)
End Function
Function LclipboardisDataFlavorSupported( aFlavor as com.sun.star.datatransfer.DataFlavor) as boolean
if aFlavor.MimeType="text/plain;charset=utf-16" then
LclipboardisDataFlavorSupported=True
else
LclipboardisDataFlavorSupported=False
end if
End Function
Sub vynulujSchranku 'delete clipboard
dim oClip as object
oClip=createUNOService( "com.sun.star.datatransfer.clipboard.SystemClipboard")
oClip.setContents(createUNOListener("Lclipboard", "com.sun.star.datatransfer.XTransferable"), Null)
gsClipboard=""
wait 50
Sub vlozDoSchranky(optional s$) 'put text to clipboard
if isMissing(s) then s=""
dim oClip as object
oClip.setContents(createUNOListener("Lclipboard", "com.sun.star.datatransfer.XTransferable") ,Null)
gsClipboard=s
Function vypisTextSchranky() as string 'show text from clipboard
dim oClip, oConv, oCont, oTyps, i%
oClip=CreateUNOService("com.sun.star.datatransfer.clipboard.SystemClipboard")
oConv=CreateUNOService("com.sun.star.script.Converter")
oCont=oClip.getContents()
oTyps=oCont.getTransferDataFlavors()
for i=lbound(oTyps) to ubound(oTyps)
if oTyps(i).MimeType="text/plain;charset=utf-16" then
msgbox oConv.convertToSimpleType(oCont.getTransferData(oTyps(i)), com.sun.star.uno.TypeClass.STRING)
exit for
end if
next
End Function
Function oDocBasicIDE() as object 'get window of Basic Editor
dim oComponents as object, oComponent as object
oComponents=StarDesktop.getComponents().createEnumeration()
if (NOT isNull(oComponents)) then
do while oComponents.hasMoreElements()
oComponent=oComponents.nextElement()
on local error goto preskoc
if oComponent.supportsService("com.sun.star.script.BasicIDE") then
oDocBasicIDE=oComponent
exit do
end if
preskoc:
on local error goto 0
loop
end if
End Function
