I have a problem opening an .odb made in 64bit machine when the file is copied to a 32bit machine(or 32 bitLO on 64bit machine) …
I checked java (+macro security ect) on each install of 32 vs 64 bit LO (where relevant);
-win7(64) PC,
-win10(64) PC,
-win8(32bit on 32efi)
-win10(‘64bit’ on 32bit efi),
-Mageia(32bit on 32bit efi)
…first issues with connection to data source (probably wrong java) but having double checked java and opening the .odb file I still get a:
“…string truncation right…gds_$send_failed…expected length 20, actual 21 …exiting…caused by isc_service_query”
each time in 32bitLO when tables/queries are selected in main menu … an error which is not present in 64bitLO on same machine (ie where machine can run either version and java is swapped)…
a fresh database (1table, no macros,no triggers, no data) works as expected when opened in 32bit and 64bit LO … I presume some problem with macros between versions…???
I will try to get some more details to troubleshoot, but any suggestions from the hive would be most welcome !
(LoveYouLibre!)
PS: all using Firebird embeded, tried with LO7.1 and LO7.2…(.odb originates from LO6.x) - java8(32 and 64bit) on windows, java11(i think) on fresh Mageia install
PPS: why 32bit anyway??? … using old mini-pcs (Linx7) as hand held data loggers > they come with a 32bit locked bios (great work MS:/) and 1 GB ram - win10 does not care, but other 64 bit winOS wont install, but will run from external live media (cpu is 64bit capable…) - for a Linux install need a modified bootia.efi, which is already included in Mageia … (Puppy Linux (live) runs really great on Linx7, but cant install due to MS 32bit uefi bios … sigh)
- so why not just stick to win10 since 64bitLO runs fine?- because win10 is so horribly bloated that 1gb ram and i/o on 20gb hdd gets pretty much maxed out…+ i am so f@@kin’ sick of killing cortana and all the other backragound crap that was never fixed by MS…
