I am using below command
/usr/bin/libreoffice5.4 --headless -convert-to pdf "<file_name>" -outdir "<root_folder/generatedreports/>";
Oh when will people stop checking checkboxes they don’t need, and stop creating “wiki” questions!..
The command line is incorrect: the --convert-to
and --outdir
require two dashes, and the former must go immediately after filter parameters, not after input file name. A minor note is that --headless
is redundant here, because it’s implied with --convert-to
libreoffice --convert-to pdf --outdir "<root_folder/generatedreports/>" "<file_name>"
but this, of course, not an answer to the question. I doubt that you can do anything here aside from getting more powerful hardware.
thanks for your correction in command. My application hosted in Openshift environment (REDHAT server) , if I increase any memory size Is it will decrease conversion time ?.
it depends. You should monitor what is the bottleneck. If your server makes excessive swapping, then yes
Thanks…
