I’m trying to create a document with 12 x A4 portrait with normal text and 2 x A4 landscape with a table on it. How do I achieve this please? It changes the whole document when I try to change just 2 pages! Please tell me this is possible!
TIA
Orientation is a property of page style. Consequently, to switch from portrait to landscape, you must insert a page break (manually or through an ad hoc style) and select the desired page style after the break. Built-in Landscape is intended for that while Default Style is in portrait orientation.
You are encouraged to read the Writer Guide to discover what can be done with styles.
If this answer helped you, please accept it by clicking the check mark
to the left and, karma permitting, upvote it. If this resolves your problem, close the question, that will help other people with the same question.
I tried that
it still did the whole document even with a page break (CTRL-Enter)
That’s not good enough, you need to do Insert - Manual break, then select landscape or portrait page style from the list.
Thank you so much, that worked! I’ve been using Open/Libre Office for years, but never had to do this before for my Daughter In Law’s Literary Review for her final year of Nursing - you’ve saved both of our sanity.
