I’ve got LO installing pretty nicely, but I have to go in and disabled JRE manually in order to speed up loading. Is there a switch for that? Thanks.
Hi Paul, are you sure Java is enable by default?
Hi @Paul1,
I don’t know of any config option for disabling java .
Please feel free to file an enhancement bug and provide as much information as possible. The QA team will be happy to help you triage your feature request in the bugtracker.
If you do file an enhancement bug, please post a link to it in a comment below using the format “fdo#123456”.
Thanks!
Thanks, qubit. I hadn’t realized there were responses here. Didn’t receive the notification. I’ll look into the report.
Thanks for this tread. If there is a way I would like to see a solution for this.
(java optionally switched off, on 4.0 or above personas turned off and online update removed would be a fine optional default for “enterprise roll out” settings)
If there is going to be a filed “bug” … for it I would upvote that if that is possible.
Other hand I would be interested in an actual workaround in that.
Hi @RudyD, Please feel free to file an enhancement bug yourself. If we have duplicates in the bug tracker, we can just mark them as such
If you do file a bug, please post a link to it here so we know that one has been filed.
Thanks!
