While saving a LibreOffice Writer file my power was cut. Windows did some repairs by it self while booting but now my file is somewhat cryptic.
It starts like this followed by 675 Pages with cryptic characters.
// Mozilla User Preferences
// DO NOT EDIT THIS FILE.
// If you make changes to this file while the application is running,
// the changes will be overwritten when the application exits.
// To change a preference value, you can either:
// - modify it via the UI (e.g. via about:config in the browser); or
// - set it within a user.js file in your profile.
user_pref("accessibility.typeaheadfind.flashBar", 0);
user_pref("app.update.auto.migrated", true);
user_pref("app.update.background.previous.reasons", "[\"cannot usually check for updates due to policy, testing configuration, or runtime environment\",\"on Windows but cannot usually use BITS\",\"not default profile\",\"the maintenance service registry key is not present\"]");
user_pref("app.update.lastUpdateTime.addon-background-update-timer", 1705262715);
Is that still my writer document or did windows replaced the content with something different? I did a google search and judging by the “Mozilla User Preferences” it seems to be somehow java related. That is strange.
