I want to put labels on 60 ml syringes, as they have no graduations. These are for measuring glue, paint etc.
I have designed a correctly-scaled drawing using a drawing programme. I can probably transfer that drawing from its drafting version to LibreOffice, even if as an inserted image.
My problem is that I then want to print that image to scale across a whole page of 100 mm * 35 mm labels that are the size that just exceeds the final scale I require.
My first query is: can I print a lot of one label, rather than multiple labels from a database. Second question, how do I get them to scale.
Is there a way to do this, please?
Thanks for any help.
I guess I have moved to the far queue
Nick
