Printing uses crazy fonts
Xubuntu 18.04
LO 6.1.5.2
$ fc-match -v 'Arial' | grep 'family:'
	family: "Arial"(s)
This Calc text, which looks fine on screen, is just bizarre when printed or exported to PDF, even though all the fonts are installed.
The screen view:
The print and export view:
Writer is just as bad, though different bad:
What’s going on?
That kind of character mess usually indicates a corrupted font cache.
There is a short command to rebuild the font cache on Linux.
sudo fc-cache -f -v
Give that a try.
That’s exactly what it was. Thanks!
