I’m trying to change the Templates folder to something other than the default. I’ve changed the Path setting via the menu Tools>Options>Paths>Templates. Then, added the new path and set it as the default. I then shutdown LibreOffice and restart. But none of the templates in the new path show up when I do File>New>Templates…
However, if I “import” the new templates, they appear. But the ‘imported’ templates show up over in the default template directory. Is there some way I can get LibreOffice to use the new templates folder and not the default?
PS: I have read the topic of “How would I update the template directory” but is doesn’t seem to apply to my version of LibreOffice.
I did learn a few things. I can see how doing a File>Save As… workflow is slightly different internally than File>Save as Template…
Thanks folks, for all your help.
