After opening a document in LibreOffice 3.5.4 (Ubuntu 12.04) from Ms-Word with an OLE object, if you use Preview the documente shows OK. If you try to print or export to PDF, the document shows a blank section where the OLE is supossed to be. Print Pictures and objects is checked. Is there another option missing?
It seems to be a bug that is there since 3.3.2 release version. See https://bugs.freedesktop.org/show_bug.cgi?id=36469
fdo#36469 – Status: RESOLVED WORKSFORME (LO 4.1.2)
